高中英语之高频短语词汇!
340条高频短语
1. learn ... by heart 用心学习,记住
2. combine ... with ... 使...与...结合/联合
3. in that circumstances 如果那样的话
4. replace ... with ... 用...代替...
5. keep a record of 记录
6. comment on ... 对...发表评论
7. at least 至少
8. expect of/from... 从...当中期待
9. in return 作为回报
10. the survey on ... 关于...的调查
11. differ in... 在...方面不同
12. emerge from... 从...出现
13. be satisfied with... 对...满意
14. play ... roles 扮演...的角色
15. lean over... 弯下身子俯身于...之上
16. turn out 结果是,证明是
17. in silence 在沉默中
18. burst into laughter 突然笑出声来
19. concentrate on ... 全神贯注于...
20. be replaced by 被...所取代
21. for the purpose of... 为了...
22. distinguish ... from ... 区分...与...
23. communicate with... 与...交流
24. one another 彼此,相互
25. by means of... 用...的方法
26. at the approach of... 在...将到的时候
27. differ from... 与...不同
28. for instance 举例来说
29. divide ... into ... 把...划分成...
30. enable sb. to do ... 使某人能够做某事
31. wave goodbye 挥别
32. in sympathy with 同情,赞成
33. look over 察看,检查,从...上面看
34. a lack of... 缺少...
35. check with... 与...协商
36. tend to do... 趋向于做...,喜欢做...
37. call after 追喊,以...命名
38. call for 要求,提倡
39. fight against 与...作战(敌人之间)
40. fight with 与...作战(战友之间)
41. agreement on ... 关于...达成的协议
42. add up 合计
43. add to 添加到
44. take ... for example 以...为例
45. in price 在价格上
46. in the long run 从长远来看,最后
47. on offer 在出售中
48. choose from... 从...中挑选
49. be curious about... 对...感到好奇
50. confront with... 使面临,使面对
51. with interest 有兴趣地
52. an average of ... 平均是...
53. at high altitudes 在很高的地方
54. draw one’s attention 吸引某人的注意力
55. focus on 集中于,专注于
56. in years to come 在未来的几年内
57. as a matter of fact 实际上
58. adopt a positive approach 采取一种正确的方法
59. wait for 等待
60. pass through 经过,通过
61. a sequence of 一系列的
62. take ... for granted 认为...理所当然
63. be aware of/that 注意到
64. translate into 翻译成
65. intend to do 想要做
66. looking forward to 期望
67. be built from... 用...建造
68. a wide variety of 多种多样的
69. at advanced levels 在高级范围内
70. carry out 完成,实施
71. according to 根据
72. aim to do 指望做某事
73. make sacrifices to do.. 做出牺牲去做某事
74. in depth 深入地
75. a series of 一系列,一连串
76. above all 首先,最重要的是
77. after all 毕竟,究竟
78. ahead of 在...之前
79. ahead of time 提前
80. all at once 突然,同时
81. all but 几乎;除了...都
82. all of a sudden 突然
83. all over 遍及
84. all over again 再一次,重新
85. all the time 一直,始终
86. all the same 仍然,照样的
87. as regards 关于,至于
88. anything but 根本不 ,决不
89. as a matter of fact 实际上
90. apart from 除...外(还有)
91. as a rule 通常,照例
92. as a result(of) 因此,由于
93. as far as ...be concerned 就...而言
94. as far as 远至,到...程度
95. as for 至于,关于
96. as follows 如下
97. as if 好像,仿怫
98. as good as 和...几乎一样
99. as usual 像平常一样,照例
100. as to 至于,关于
02
101. all right 令人满意的;可以
102. as well 同样,也,还
103.as well as 除...外(也),即...又
104. aside from 除...外(还有)
105. at a loss 茫然,不知所措
106. at a time 一次,每次
107. at all 丝毫(不),一点也不
108. at all costs 不惜一切代价
109. at all events 不管怎样,无论如何
110. at all times 随时,总是
111. at any rate 无论如何,至少
112. at best 充其量,至多
113. at first 最初,起先
114. at first sight 乍一看,初看起来
115. at hand 在手边,在附近
116. at heart 内心里,本质上
117. at home 在家,在国内
118. at intervals 不时,每隔...
119. at large 大多数,未被捕获的
120. at least 至少
121. at last 终于
122. at length 最终,终于
123. at most 至多,不超过
124. at no time 从不,决不
125. by accident 偶然
126. at one time 曾经,一度;同时
127. at present 目前,现在
128. at one's disposal 任...处理
129. at the cost of 以...为代价
130. at the mercy of 任凭...摆布
131. at the moment 此刻,目前
132. at this rate 照此速度
133. at times 有时,间或
134. back and forth 来回地,反复地
135. back of 在...后面
136. before long 不久以后
137. beside point 离题的,不相干的
138. beyond question 毫无疑问
139. by air 通过航空途径
140. by all means 尽一切办法,务必
141. by and by 不久,迟早
142. by chance 偶然,碰巧
143. by far 最,...得多
144. by hand 用手,用体力
145. by itself 自动地,独自地
146. by means of 用,依靠
147. by mistake 错误地
148. by no means 决不,并没有
149. by oneself 单独地,独自地
150. by reason of 由于
151. by the way 顺便说说
152. by virtue of 借助,由于
153. by way of 经由,通过...方法
154. due to 由于,因为
156. each other 互相
157. even if/though 即使,虽然
158. ever so 非常,极其
159. every now and then 时而,偶尔
160. every other 每隔一个的
161. except for 除了...外
162. face to face 面对面地
163. far from 远非,远离
164. for ever 永远
165. for good 永久地
166. for the better 好转
167. for the moment 暂时,目前
168. for the present 暂时,目前
169. for the sake of 为了
170. for the time being 暂时,眼下
171. from time to time 有时,不时地
172. hand in hand 手拉手,密切关联
173. head on 迎面地,正面的
174. heart and soul 全心全意地
175. how about ... ...怎么样
176. in a hurry 匆忙,急于
177. in case of 假如,防备
178. in a moment 立刻,一会儿
179. in a sense 从某种意义上说
180. in a way 在某种程度上
181. in a word 简言之,总之
182. in accordance with 与...一致,按照
183. in addition 另外,加之
184. in addition to 除...之外(还)
185. in advance 预先,事先
186. in all 总共,合计
187. in any case 无论如何
188. in any event 无论如何
189. in brief 简单地说
190. in charge of 负责,总管
191. in common 共用的,共有的
192. in consequence(of) 因此;由于
193. in debt 欠债,欠情
194. in detail 详细地
195. in difficulty 处境困难
196. in effect 实际上,事实上
197. in general 一般来说,大体上
198. in favor of 支持,赞成
199. in front of 面对,在...前
200.in half …成两半
03
201. in hand 在进行中,待办理
202. in honor of 为庆祝,为纪念
203. in itself 本质上,就其本身而言
204. in line with 与...一致
205. in memory of 纪念
206. in no case 决不
207. in no time 立即,马上
208. in no way 决不
209. in order 按顺序,按次序
210. in other words 换句话说
211. in part 部分地
212. in particular 特别,尤其
213. in person 亲自,本人
214. in place 在合适的位置
215. in place of 代替,取代,交换
216. in practice 在实践中,实际上
217. in proportion to 与...成比例
218. in public 公开地,当众
219. in quantity 大量
220. in question 正在谈论的
221. in regard to 关于,至于
222. in relation to 关于,涉及
223. in return 作为报答/回报/交换
224. in return for 作为对...的报答
225. in short 简言之,总之
226. in sight 被见到;在望
227. in spite of 尽管
228. in step 齐步,合拍
229. in step with 与...一致/协调
230. in tears 流着泪,在哭着
231. in the course of 在...期间/过程中
232. in the distance 在远处
233. in the end 最后,终于
234. in the event of 如果...发生,万一
235. in the face of 即使;在...面前
236. in the first place 首先
237. in the future 在未来
238. in the least 丝毫,一点
239. in (the)light of 鉴于,由于
240. in the way 挡道
241. in the world 究竟,到底
242. in time 及时
243. in touch 联系,接触
244. in turn 依次,轮流;转而
245. in vain 徒劳,白费力
246. instead of 代替,而不是
247. just now 眼下;刚才
248. little by little 逐渐地
249. lots of 许多
250. many a 许多
251. more or less 或多或少,有点
252. next door 隔壁的,在隔壁
253. no doubt 无疑地
254. no less than 不少于...;不亚于...
255. no longer 不再
256. no more 不再
257. no more than 至多,同...一样不
258. none other than 不是别的,正是
259. on one's guard 警惕,提防
260. nothing but 只有,只不过
261. now and then 时而,偶尔
262. off and on 断断续续,间歇地
263. off duty 下班
264. on a large/small scale 大/小规模地
265. on account of 由于
266. on(an/the) average 平均,通常
267. on behalf of 代表
268. on board 在船(车/飞机)上
269. on business 为了公事,出差
270. on condition that 如果
271. on duty 上班,值班
272. on earth 究竟,到底
273. on fire 起火,着火
274. on foot 步行
275. on guard 站岗,值班
276. on hand 在场,在手边
277. on occasion(s) 有时,间或
278. on one's own 独立,独自
279. on purpose 故意地
280. on sale 出售,廉价出售
281. on schedule 按时间表,准时
282. on second thoughts 经重新考虑
283. on the contrary 正相反
284. on the grounds of 根据,以...为由
285. on (the) one hand 一方面
286. on the other hand 另一方面
287. on the point of 即将...的时刻
288. on the road 在旅途中
289. on the side 作为兼职/副业
290. on the spot 在场;马上
291. on the whole 总的来说,大体上
292. on time 准时
293. once again 再一次
294. once(and)for all 一劳永逸地
295. once in a while 偶尔
296. once more 再一次
297. once upon a time 从前
298. one another 相互
299. or else 否则,要不然
300. or so 大约,左右
04
301. other than 非;除了
302. out of 从...中;由于;缺乏
303. out of breath 喘不过气来
304. out of control 失去控制
305. out of date 过时的
306. out of doors 在户外
307. out of order 出故障的
308. out of place 不合适的,不在适当的位置
309. out of practice 久不练习,荒疏
310. out of sight 看不见,在视野外
311. out of the question 毫无可能的
312. out of touch 不联系,不接触
313. over and over(again) 一再地,再三地
314. prior at 在...之前
315. quite a few 相当多,不少
316. rather than 不是...(而是)
317. regardless of 不顾,不惜
318. right away 立即,马上
319. speak about 谈及
320. set in 开始
321. set apart from 把...区分开
322. side by side 肩并肩,一起
323. so far 迄今为止
324. sooner or later 迟早,早晚
325. step by step 逐步地
326. such as 例如,诸如
327. thanks to 由于,多亏
328. that is (to say) 就是说,即
329. to the point 切中要害,切题
330. under control 处于控制之下
331. under the circumstances 这种情况下
332. up to date 在进行中
333. up to 多达;直到;胜任;取决于
334. what if 假使...将会怎样
335. what about ...怎么样
336. with respect to 如果...将怎样
337. with regard to 关于,至于
338. without question 关于,至于
339. with the exception of 除...之外
340. word for word 逐字地
完形填空415个高频词
1. occasion 场合
2. situation 情况,处境
3. take over 接管
4. exchange 交换
5. command 命令
6. confirm 证实
7. cultivate 培养
8. prosperously 繁荣的
9. suspect 怀疑
10. relatively 相对的,比较的
11. acknowledge 承认,鸣谢
12. ambition 抱负,野心
13. quality 质量,品质
14. protection 保护
15. equally 平等地
16. promise 承诺
17. clearly 清楚地
18. grateful 感激的
19. remove 移开
20. force 强迫
21. apologize 道歉
22. terrible 可怕的,糟糕的
23. stubborn 固执的
24. actively 积极地,主动地
25. spiritual 精神的,心灵的
26. magical 魔力的
27. willingly 愿意地
28. strengthen 加强
29. image 形象
30. complexity 复杂
31. cautious 小心的
32. manage 管理,成功做成
33. prejudice 偏见
34. economic 经济的,合算的
35. academic 学术的
36. control 控制
37. adopt 收养,采取
38. consume 消费,消耗
39. unique 独一无二的
40. beneficial 有益的
41. varied 多变的,各种各样的
42. demanding 要求高的
43. appropriate 合理的
44. entertainment 娱乐
45. deliberately 故意地
46. purchase 购买
47. tough 艰难的
48. bright 明亮的
49. remain 留下,保持
50. terrify 使害怕
51. disappointing 令人失望的
52. formal 正式的
53. desire 愿望
54. share 分享,共有
55. fulfill 履行(诺言),执行(命令)
56. admit 承认
57. evident 明显的
58. consequently 因此,所以
59. accustomed 习惯的
60. accumulate 积累
61. participate 参加
62. absence 缺席
63. presence 出席
64. bravery 勇敢
65. horror 恐惧
66. spotless 无暇的
67. fundamental 基础的
68. employment 就业,雇用
69. involve 包含,使参与
70. actually 事实上
71. harmony 和谐
72. basically 基本的
73. inspire 激发,鼓舞
74. imitate 模仿
75. awful 糟糕的
76. generous 慷慨的,大方的
77. wealthy 富有的
78. function 功能
79. stressful 有压力的
80. persistent 坚持不懈的
81. reluctant 勉强的,不愿意的
82. diligent 勤奋的
83. attentive 注意的,周到的
84. unbearable 不能忍受的
85. accommodation 住所
86. attractive 有吸引力的
87. constant 连续的
88. brilliant 杰出的,才华横溢的
89. clumsy 笨拙的
90. declare 宣布,声明
91. obtain 获得
92. interactive 相互的,互动的
93. incident 事件
94. adventure 冒险
95. in particular 尤其
96. in reality 事实上
97. emphasize 强调
98. overlook 忽视
99. deny 否认
100. ensure 确保
101. financial 金融
102. budget 预算
103. on the whole 整体上
104. potential 潜在的,潜能
105. on the contrary 相反
106. loyalty 忠实
107. assume 假设
108. establish 建设
109. flexible 灵活的
110. sensitive 敏感的
111. essential 必不可少的
112. unfair 不公平的
113. expectation 期待
114. impression 印象
115. examination 考试,检查
116. contribution 贡献
117. certainty 肯定
118. confuse 使迷惑,使混淆
119. trap 陷阱,困住
120. secondary 次要的
121. turn up 出现
122. show off 炫耀
123. break in 闯进
124. settle down 定居,安定下来
125. relief 安慰,减轻
126. justice 公正
127. previous 先前的,早先的
128. instantly 立即地
129. regularly 规则地,规律地
130. occasionally 偶尔地
131. independence 独立
132. keep up with 跟上
133. catch up with 追赶上
134. come up with 想出
135. put up with 忍受
136. guarantee 保证
137. convince 使确信,说服
138. atmosphere 气氛
139. sympathy 同情
140. punish 惩罚
141. puzzled 感到迷惑的
142. scared 害怕的
143. embarrassed 尴尬的
144. reaction 反应
145. forgiveness 原谅
146. imaginary 想象力丰富的
147. be filled with 充满
148. be pleased with 对......感到满意
149. be crowded with 挤满
150. be equipped with 配备有......
151. possession 财产
152. precious 珍贵的
153. appreciate 欣赏,感激
154. admire 钦佩
155. wander 闲逛
156. get rid of 消除,摆脱
157. particularly 尤其,特别
158. purpose 目的,意图
159. courage 勇气
160. determination 决心
161. roll 滚
162. drop 掉下
163. undoubtedly 毫无疑问地
164. temporarily 暂时地
165. thankfully 幸运地
166. lean against 靠着
167. challenge 挑战
168. fierce 激烈的
169. practical 实际的,实用的
170. straight 直接的
171. delighted 高兴的
172. congratulate 祝贺
173. faint 头晕的
174. consult 咨询
175. messy 乱的
176. review 复习,评论
177. curious 好奇的
178. graduation 毕业
179. honor 荣耀
180. comfortable 舒服的,舒适的
181. tiresome 令人生厌的,无聊的
182. set up 建立
183. hold up 举起,支撑
184. pick up 拾起,学会,接
185. possess 拥有
186. crowded 拥挤的
187. march 行军,前进
188. apartment 公寓
189. frightened 害怕的
190. turn out 结果是,证明是
191. figure out 算出,想出
192. anxious 焦虑的
193. hunt 寻找,打猎
194. amused 愉快的,顽皮的
195. optimistic 乐观的
196. demonstrate 证明,演示,显示
197. realize 意识到
198. meaningful 有意义的
199. faithful 忠实的,忠诚的
200. grasp 抓住,理解
201. decorate 装饰
202. pressure 压力
203. obvious 明显的
204. predict 预测
205. audience 观众
206. contain 包含
207. gesture 姿势
208. pioneer 先锋
209. afford 支付得起
210. affair 事情
211. dependent 依赖的
212. properly 合理地
213. sincerely 真诚地
214. severely 严厉地
215. guidance 指导
216. appearance 出现,外貌
217. astonishment 惊讶
218. sharpen 使锋利
219. comment 评论
220. privately 私人地
221. frequently 频繁地
222. physical 身体的,物理的
223. donate 捐赠
224. manufacture 制造,制造业
225. original 原始的,起初的
226. effective 有效的
227. object 反对
228. typical 典型的
229. possibility 可能性
230. accidentally 意外地,偶然地
231. immediately 立刻
232. concern 关心,担心
233. concentrate 集中
234. tragedy 悲剧
235. neglect 忽视
236. approach 接近,途径,方法
237. disturbance 打扰
238. arrest 逮捕
239. restore 恢复
240. available 可得到的, 可利用的
241. accompany 陪伴
242. characteristic 特征,特性
243. automatic 自动的
244. approve 批准,同意
245. roughly 粗略地
246. indicate 暗示
247. hesitation 犹豫
248. attach 系着,附着
249. plain 平的,朴素的,简单的
250. mercy 怜悯
251. sample 样本
252. considerable 相当大的,值得考虑的
253. enthusiasm 热情
254. confirm 证实
255. phenomenon 现象
256. modify 修改
257. annual 每年的
258. isolation 隔离,孤立
259. ceremony 典礼,仪式
260. acceptable 可接受的
261. eventually 最后
262. target 目标
263. expose 暴露
264. absolutely 绝对地
265. negative 消极的,否定的
266. steady 稳定的
267. consistently 一贯地,一致地
268. permanent 永久的
269. professional 职业的,专业的
270. dismiss 解雇
271. countless 数不尽的
272. thoroughly 彻底地
273. standard 标准
274. tolerate 忍受
275. memorable 值得纪念的
276. leave for 离开去到
277. adapt 适应,改编
278. somehow 不知怎么地
279. somewhat 稍微,有点
280. acquire 获得
281. occupy 占据
282. accompany 陪伴
283. urgent 紧急的
284. technology 技术
285. giant 巨大的
286. invisible 看不见的
287. evaluation 评估
288. magnificent 壮丽的
289. inefficient 效率低的
290. nonsense 废话,荒谬的
291. preserve 保护,保存
292. career 事业
293. profession 职业,专业
294. exhausted 筋疲力尽的
295. crash 撞碎,坠毁
296. suspicious 怀疑的
297. requirement 要求
298. athletic 运动的,运动员的
299. prohibit 禁止,阻止
300. depressed 沮丧的,萧条的
301. instruction 教导,说明
302. slightly 轻微地
303. meaningful 有意义的
304. principle 原则
305. undeserved 不应得的
306. betray 背叛
307. moderate 中等的,适度的
308. evaluate 评价,估价
309. honorable 值得尊敬的
310. artificial 人造的
311. concept 概念
312. symbolize 象征
313. promising 有前途的
314. conflict 冲突
315. display 显示,陈列
316. definitely 明确地,肯定地
317. interrupt 打断
318. recall 回想起
319. recite 背诵
320. resist 抵制
321. desperate 绝望的
322. elegant 优雅的
323. attempt 试图
324. random 随机的
325. profitable 有利可图的
326. treasure 珍惜,宝藏
327. poisonous 有毒的
328. dilemma 窘境
329. correctly 正确地
330. system 系统
331. complicated 复杂的
332. application 申请,应用程序
333. simple 简单的
334. recognize 认出,认可
335. cruel 残忍的
336. comfortable 舒服的,舒适的
337. feared 害怕的
338. replace 代替
339. method 方法
340. seize 抓住
341. misunderstand 误解
342. mistake 错误,弄错
343. imply 暗示
344. disease 疾病
345. repay 偿还,报答
346. describe 描述
347. contract 合同
348. promote 促进,提升
349. sacrifice 牺牲
350. generally 一般来说
351. trouble 麻烦
352. pleased 满意的
353. certainly 肯定地,当然
354. national 国家的,民族的
355. cultural 文化的
356. entrance 入口
357. annoying 令人恼怒的
358. polite 有礼貌的
359. unconscious 无意识的
360. patient 有耐心的
361. theory 理论
362. classification 分类
363. smart 聪明的
364. mature 成熟的
365. average 平均
366. creative 有创造力的
367. graduate 毕业,毕业生
368. program 节目
369. intelligent 智能的,聪明的
370. competent 有能力的
371. independent 独立的
372. separate 单独的,分开的
373. voluntarily 自愿地
374. doubt 怀疑
375. reflection 反射,沉思,映象
376. conclusion 结论
377. adult 成年人
378. talented 有天赋的
379. outstanding 出色的
380. expression 表达,表情
381. check 检查
382. attend 参加,照料
383. be aware of 意识到
384. be fond of 喜欢
385. be worthy of 值得
386. expect 期待,预计
387. decision 决定
388. style 风格
389. pretend 假装
390. explain 解释
391. cause 原因,事业
392. perform 表演,执行
393. probably 可能地
394. struggle 挣扎,奋斗
395. completely 完全地
396. wonder 想知道
397. experience 经验,经历
398. fail 失败
399. develop 发展
400. responsible 有责任的
401. valuable 有价值的,贵重的
402. ability 能力
403. affect 影响
404. destroy 毁坏
405. confident 自信的
406. request 要求
407. traditional 传统的
408. modern 现代的
409. relationship 关系
410. cooperation 合作
411. distinguish 区分
412. identify 鉴定,识别
413. thought 想法,思想
414. discourage 使气馁,使沮丧
415. prepare 准备
