【北京英语学习】that's ok什么意思
少儿英语学习
that's ok的中文释义为那好吧。例句:But that's OK, we can still release!但是没关系,我们还是可以发布的!If that's OK with you.如果这样对你可以的话。
that's ok 可以;那好吧
例句:
1.That's OK. I'm just looking around.
没关系,我只是随便看看。
2.If that's OK with you.
如果这样对你可以的话。
3.I'd rather email than phone, if that's OK by you.
如果你认为可以的话,我想发电邮而不打电话。
4.That's OK: the difference between some tests and no tests is much larger and more significant than the difference between all tests and some tests.
这样也可以,因为做一些测试和不作测试的区别比做所有的测试和做一些测试的区别更大更重要。
5.And yeah, I know it comes built in, that's ok, what we want to do is use it as an example to look at it.
对,我知道这个方法可以通过内置的算法,来实现,这没关系,我们只是,把它当做一个例子来讲解。
6.Arguments happen and that's OK. But with love, understanding, and some work, families can solve almost any problem.
当争吵发生时,人们应该多包容,理解,这样是可以解决大部分问题的。
7.A little flaky, but that's OK. You've also proven... to be very brave.
有一点奇怪,但是总体来说,还可以……你也证明了,你很勇敢。
8.Because it's the same actor who plays the Beast Avenant, and then again Prince Charming I had a question? That's OK?
因为演野兽,阿瓦南,还有王子的都是同一个演员,我有一个问题,可以说么?
9.Victoria: Harvey, I prefer Victoria, if that's OK.
维多利亚:哈维,请你叫我维多利亚就可以了。
10.Some things take time, but that's OK.
总有事情要花费时间,但是这样很好。
11.But that's OK, we can still release!
但是没关系,我们还是可以发布的!
12.You will miss a ton, but that's OK.
你将错过很多事情,但这是很正常的。
13.That's OK — it's actually possible to do a little work that can result in the same benefits I've just described.
那么好吧——实际上可以通过少量的工作来获得前述的效果。
14.If the previous discussion leaves you feeling intimidated, that's OK — working with databases has historically been difficult.
如果前面的讨论让您觉得有点害怕,那就对了——操作数据库历史上来说一直都很难。
15.If you come up with a brilliant idea, that's OK.
如果你有一个好的想法,那很好。
16.After this, you can graduate to the next step, or if you'd like to stay in this step for a week or two longer, that's OK.
这以后,你可以进入下一个步骤,不然,若你想在这一步多花费一到两周时间,也行。
17."That's ok! First sit down please and have an apple for a rest" the Spring Rabbit said..
蹦蹦兔说:不介意就好!您先坐下来,吃个苹果休息一会儿。
18.Alright, sometimes you just want to go all out. And that's ok!
有时候,你需要全力以赴,没问题,戴上这个头盔,你就成了中世纪的武士!
19.So that's OK then?
那就可以了吗?
20.But that's OK, because you can easily apply the Adapter design pattern to link the ViewModel document manager to the third-party view component.
但是这也没关系,因为您可以轻松应用适配器设计模式,将ViewModel文档管理器链接到第三方视图组件。
